Any non-common tools I should get before replacing the head gasket?
Old Dec 5, 2021 | 10:26 AM
The_OGCJR's Avatar
I would suggest a bolt extractor socket set. Just In case. See pic
Old Dec 5, 2021 | 10:29 AM
disco96sd's Avatar
yes seals - typo
Old Dec 5, 2021 | 11:19 AM
Alex_M's Avatar
Originally Posted by mln01
Brandon didn't say anything about replacing the oil pump. Let's not confuse him!
Highly recommended to replace it while you've got the engine torn apart for head gaskets.
Old Dec 5, 2021 | 12:08 PM
greisinb's Avatar
Originally Posted by Richard Gallant
Some 12 point sockets 8mm for the valve cover, I think 12 for the exhaust a manifold, and if you have SAI some thin wrenches I forget the size
Make sure the 8mm 12pt is a 1/4” drive, a 3/8” won’t fit in to the recess.
Old Dec 5, 2021 | 12:10 PM
Brandon318's Avatar
lol. Replaced that and the timing chain/gears a few months ago anyway 😂
Old Dec 5, 2021 | 07:17 PM
PalmettoDisco's Avatar
A piece of pipe to extend the breaker bar length to break the old head bolts loose.
Also, be aware if new stretch head bolts are used, you will finish up by making quarter turn tightening. You may want a way to mark those turns accurately.
Old Dec 6, 2021 | 05:20 AM
Alex_M's Avatar
Ah, good call. Paint markers work great for this. I like the Sharpie branded oil base paint markers.
Old Dec 6, 2021 | 05:45 AM
redwhitekat's Avatar
highly recommend you watch the atlantic british video of a head gasket job, shows you the procedures and all the tools they use to make this easier
Old Dec 6, 2021 | 08:32 AM
matt3502's Avatar
The AB videos (teardown and rebuild) were my spirit guides when I did my heads earlier this year. Watch them before you start and refer them often. The suggestion of getting food delivery trays was fantastic as I labeled each one so I did not have to play around finding the right bolts etc.
Old Dec 6, 2021 | 08:54 AM
mln01's Avatar
I just used a standard, black Sharpie, I recall.
