any one herd of this ?
ok it started when i parked my 200 v 2.5 tdi on the path for a few days
i tryed to start it but no fuel pump engaged and the hazards flashed
so after reseting via the key in drivers door . and reseting the switch but
still the same .
i got a land rover guy with a diagnostics and he said he thinks a sensor on the pass side under the bon wireing fault
ineed my lanny he says he can fix takes 3 hours prob is i can't get it of my path to tow it the angle iv reversed on any in put ?
still the same .
Squirrel or rat ate off some wiring I bet. Some ground wires in the fenders got eaten I bet.
Light are flashing now as there is a mis configuration and the ECU has noticed.
Or -
you may have a security problem.
With the key in and turned on - if the red theft or warning light is flashing then you will not start.
Or -
Howdy all! Newbie to the scene. Actually, I don't even have one yet:) But I have a plan! A long one.
jdog35
04-19-2008 03:16 PM
tuwrx
03-26-2008 07:26 PM
