any one herd of this ?
Old Mar 7, 2013 | 04:25 PM
seanyboy's Avatar
4wd High
Default any one herd of this ?
ok it started when i parked my 200 v 2.5 tdi on the path for a few days
i tryed to start it but no fuel pump engaged and the hazards flashed
so after reseting via the key in drivers door . and reseting the switch but
still the same .
i got a land rover guy with a diagnostics and he said he thinks a sensor on the pass side under the bon wireing fault
ineed my lanny he says he can fix takes 3 hours prob is i can't get it of my path to tow it the angle iv reversed on any in put ?
Old Mar 7, 2013 | 05:53 PM
ZGPhoto's Avatar
Sorry, is this a Discovery 1?
Old Mar 7, 2013 | 11:21 PM
jfall's Avatar
Squirrel or rat ate off some wiring I bet. Some ground wires in the fenders got eaten I bet.
Light are flashing now as there is a mis configuration and the ECU has noticed.
Or -
you may have a security problem.
With the key in and turned on - if the red theft or warning light is flashing then you will not start.
Old Mar 10, 2013 | 06:32 PM
seanyboy's Avatar
4wd High
hi its a disco 2 . i tried today to get it of the path to take to the garage i can't do it ahhhhhhh
tomorrow im gona have another look at these censers one either side under the bonnet
any one no of any more 9th day without me lanny
Old Mar 25, 2013 | 01:02 PM
seanyboy's Avatar
4wd High
ok theres no security problem i think now it could be a bad earth ?
Shiftonthefly1
Jun 19, 2015 05:45 AM
disconewb
Dec 14, 2011 06:32 PM
ljdiscovery
May 16, 2010 02:23 PM
tuwrx
Mar 26, 2008 07:26 PM
