Anyone else with this starter issue?
Recently a D2 of mine has been failing to start.
Key illuminates all dash lights, turn to crank and nothing. No click, no sound, nothing.
newer battery. Can confirm adequate voltage
New starter say 4/5 years ago.
The cable from battery to starter selinoid is clean & tight, as is the battery terminal connections.
there is a small red wire with a pinch blade connection to the back/bottom of the starter. It appears to be wrapped in a foil heat shield. If I apply pressure to that connection - as if it’s sliding off slightly- truck fires right up strong.
Im leaning towards maybe mice? Tearing at the foil shield and tugging the connection loose just enough to have an issue? Seems far fetched - or does it?
My question is has anyone else had similar issue?
I want to say that red wire is part of some sort of ignition circuit for alarm or lockout in the event of theft or break in?
Buzzwalburg
01-02-2012 08:55 PM
