Anyone in FL. running a .....
Old Apr 20, 2019 | 07:33 PM
Nosugar0carbs's Avatar
Default Anyone in FL. running a .....
Anyone running a meziere remote thermostat and aluminum radiator in FL? Would you know your min/max coolant temperature? Which thermostat? Type of driving. Thank you.
Old Apr 21, 2019 | 02:33 AM
DavidOHendo's Avatar
Banned
a what?
Old Apr 21, 2019 | 06:58 AM
Ben Matheson's Avatar
Bypass mod
Old Apr 21, 2019 | 07:54 AM
Red5's Avatar
Can't speak from experience since I am not and have not. But I would expect 180-195 is reasonable.
Are you asking about Meziere units specifically? There are many here with the inline thermostat but I'd be surprised if anyone is spending that kind of $$ for a radiator.
Old Apr 21, 2019 | 09:07 AM
I haven’t measured the temp with the scanner post upgrades, but in south Florida heat, 5 discos hit 212*F and drop maybe 10* till the six fan shuts off, then back up and repeat. Radiator doesn’t have to be specific to the car, just a full aluminum radiator for comparison.
Old Apr 21, 2019 | 09:11 AM
more so the Meziere remote thermostat and their perspective cooling system routing as well (with heater core/without, throttle body heater/with out,etc). Trying to gauge what others temps are and with what set-up as well
Old Apr 21, 2019 | 11:05 AM
Red5's Avatar
For comparison then, I have a 180 deg thermostat and a Hayden HD clutch, otherwise stock setup. TBH and heater core still connected. Just recently replaced the rad with a cheap Amazon unit (prime choice was the name I think), alum fins and plastic end caps, although it did not change my temps. I had a slow leak in the top side near the small hose that goes to the plastic reservoir so I replaced it while doing the HGs.
For mine, 60 mph seems to be the tipping point. Above 60 on the highway, I'm in the high 170s in the morning, to low 180s in the afternoon. Below 60, or in stop and go traffic, I'm at 185-195. If I have a long, low speed climb I may see around 200, but it quickly drops back down once I get back up to speed. Mine doesn't seem to care if its 45 or 85 outside. If it's over 95 it may go a few degrees higher.
Old Apr 21, 2019 | 10:40 PM
attworth's Avatar
I’m with Red5, same setup, and similar temps. It does the same whether it’s 10 degrees outside or 105 and humid.
Old Apr 22, 2019 | 12:18 AM
Daedrix's Avatar
Banned
185-195F, hood louvers, stock rad, and a ford taurus electric fan. I live in Jacksonville FL.
FlyingZebra34
Jan 8, 2019 07:51 AM
silar
May 26, 2013 10:18 AM
kjordan
Mar 15, 2013 10:27 PM
ebg18t
Aug 8, 2012 05:44 AM
Chris in Maui
Mar 25, 2009 12:29 AM
