anyone know what these connectors are for?
Old Feb 3, 2013 | 09:20 AM
wkburns's Avatar
Default anyone know what these connectors are for?
I am wiring in some extra interior lights (map lights and two rear cargo lights). While removing the panels to install them I ran across these two connectors. If they are not in use I was thinking of patching into them for power. I tried to find them in the Rave to no success.
This one is on the rear driver side up by the alpine window.
This one was taped up in foam and is in the overhead council with the sunroof controls.
Thanks for any help.
Old Feb 3, 2013 | 09:34 AM
Those are for the alarm system's sonic sensors that came with most but not all Disco's.
jafir's Avatar
The one in the rear cargo area might be for the alarm system's volumetric sensor. There should be another one one the left side above the drivers' head.
Old Feb 3, 2013 | 09:54 AM
hmmmm.... looks like too many wires for the alarm on that rear photo. Both of the motion sensors (volumetric detectors, ultrasonic) use a black, a white & black, and two wires that are purple and gray, or gray and purple. The black goes to frame ground, the others back to the BCU.
Old Feb 3, 2013 | 10:01 AM
jafir's Avatar
Perhaps an ace sensor then?
Old Feb 3, 2013 | 11:00 AM
wkburns's Avatar
Would they work as a power source do you think? My lights are 6w each.
Old Feb 3, 2013 | 11:05 AM
Nope, if they come from BCU they are low current. But there may be other wires in that area you could mooch from, crack out the RAVE circuits manual, and look for things in that are nearby (mirror, dome lights, etc.). That will give you the wire color and what fuse it links back to. It will also show some small numbers, to identify the connector, you look those up in the electrical library and get a color pix of the location and pin out for the connector.
Old Feb 3, 2013 | 11:07 AM
wkburns's Avatar
The front ones should be no issue as I can tap into the existing dome light. I doubt two 6w lights will over do the wiring for that portion.
pinkytoe69
Aug 1, 2012 07:56 AM
pinkytoe69
Feb 29, 2012 09:00 AM
TRIARII
Oct 3, 2011 07:20 PM
twaszak
Mar 24, 2011 04:37 PM
VikingDiesel
May 26, 2009 02:43 PM
