Anyone replaced a torque converter?
Old 07-22-2023 | 02:21 PM
miron's Avatar
Default Anyone replaced a torque converter?
If anyone has replaced the torque converter, I'd really appreciate any pointers on how and what should I be looking out for.
thanks!
Old 07-22-2023 | 11:48 PM
sdtimb's Avatar
I haven't, but the instructions should be in the RAVE (D2 workshop manual). Do you have a copy?
Old 07-23-2023 | 12:02 AM
miron's Avatar
I do have a copy, but you know there are always some special tricks etc.
The_OGCJR (07-28-2023)
Old 07-23-2023 | 06:55 AM
Alex_M's Avatar
If you're replacing the torque converter, you really should replace/rebuild the trans and flush out the tranny cooler lines at the same time. The debris from your old converter will have gone through the entire system.
Old 07-23-2023 | 12:27 PM
miron's Avatar
That was the plan, but the rebuild kit costs as much as a whole transmission from a wrecker. I'll see what shows up on the filter, but it's hard to justify paying $400 for a few gaskets.
Old 07-23-2023 | 02:37 PM
Extinct's Avatar
Alex_M is right, just swap the entire transmission. They almost never go out,better use of your time and money to just swap it.
Old 07-23-2023 | 03:10 PM
miron's Avatar
Yes, sorry the "rebuild" somehow got stuck in my head. Replace is definitely a viable option.
Old 07-23-2023 | 05:46 PM
Richard Gallant's Avatar
@miron If you doubts have it done by a shop, Automatic transmission and brakes if you are not sure get it done professionally.
Old 07-23-2023 | 05:50 PM
miron's Avatar
I don't have issues with the mechanical part. It's mostly the financial side of thing.
Also on another note, why does a rebuild kit for the hp22 doe a bmw cost half as much ase the one for LR? They seem to be pretty much identical...
Old 07-23-2023 | 08:03 PM
ahab's Avatar
If it’s a 4HP24EH then it’s the same trans. BMW also used the 4HP22, which I think is a D1 trans. Either way, the kits should be the same for their respective transmissions.
Quick Reply: Anyone replaced a torque converter?
