Anyone tried the "Radiator Classic" on eBay for $127?
Old Jul 26, 2013 | 08:43 PM
  #21
ralphobell's Avatar
This is the model that is probley the closest fit.
ALUMINUM RADIATOR GM CHEVY 16" x 28" LOW PROFILE - KMJ Performance
However if you would like one that is designed for the Disco then take a look at this one.
Allisport Discovery V8 Direct Replacement Alloy Radiator with Two Oil Coolers | eBay
Old Sep 16, 2013 | 02:37 PM
  #22
bcolins's Avatar
Default Update: bought the $127 SILLA radiator,....all good so far
So many things needing work on this 03 D2, I was running out of funds in a hurry, so, thinking a new radiator without the usual leak at the upper mounting screw, was a good investment. Looked more or less identical to the unit that came out of it,....and so far, so good. No leaks, other than that pesky upper radiator bleed screw, and and temps right in the middle of the gauge on 100 degree days.
Old Sep 16, 2013 | 04:13 PM
  #23
The temps will be right in the middle - because the gauge is made to show that spot for about 130 -240F. Please check with an OBDII connected scanner to be sure, look for coolant temp.
Old Sep 16, 2013 | 04:52 PM
  #24
bcolins's Avatar
Thanks for the heads-up on that Buzz. My Scanner shows 197-199 while driving and 201-203 while idling with a stock thermostat.
I Looked at 180 Degree Thermos,....seems to me they were $65 and I decided to pass, since the truck wasn't overheating when I replaced the radiator (it was leaking from the upper mounting point where the screw goes into the tank,..my last Disco did the same thing)
Brian
bcolins
Sep 18, 2013 10:31 PM
Bajapower
ROAMING WITH FRIENDS
Aug 31, 2010 10:45 PM
DDLR3
Mar 3, 2008 01:31 PM
badfysh
Aug 7, 2007 09:42 PM
razorbak
Aug 6, 2005 04:11 AM
