Anyone try these? Window regulator repair
Old Jan 13, 2023 | 07:49 AM
keninnc's Avatar
My luck of not having to deal with a window regulator just ran out.
So here is my question.
Can new rollers be installed while the actuator is still attached to the door and the window is still attached to the actuator?
If I need to replace the rollers by removing the actuator completely I will replace the entire unit.
Thanks,
Old Jan 13, 2023 | 01:18 PM
XRAD's Avatar
no. you can't install new rollers with mechanism in the door. it is easier to get a britpart mechanism for 40$ and install the whole unit, rather than finding correct rollers and a strong way to mount them....they are pressed pins, and sometimes spot welded...
EDIT: Correction to above: Cost has gone up on Britpart since december ! it's now ~60-70$...depending on vendor....
Old Jan 13, 2023 | 08:14 PM
Extinct's Avatar
Thanks,
Yes, can be done with the shapeways parts but I find removing the actuator almost as easy. The $40 price is a pretty good price though for a complete unit,
NabisOne
Sep 4, 2013 12:20 PM
parkerlander
Jul 25, 2013 09:52 PM
cbjnick
Sep 20, 2010 04:13 PM
outback96
Dec 13, 2009 05:38 PM
Classklown90
Oct 24, 2009 03:36 PM
