Anyone using Torque for OBD II to check temp
After installing my head gaskets I headed down to LA for a road test. I have the Torque ap for my phone with a OBD II blue tooth reader. The temp gauge reads normal all day long. Today sitting in traffic the gauge still reads in the middle but the the phone ap got up to 225 is this a normal tempature?
Perfectphoto (04-13-2015)
I second the opinion.... 225-deg is high, especially when the aircon electric fan should kick in at 212-deg to bring the temps down.
I advise also checking the electric fan to see if it is working. If the fan is working, it will point more likely to a clogged radiator as the culprit. This will what happened to me last summer as I was going through the process of deduction to figure out the same issue.
I used torque for quite some time before adding an actual aftermarket temp sensor. It's very reliable, I just got tired of it draining my phone battery. 225 is way high, I've only ever had my aux fan turn on once and it came right back down to 203, which it has never passed other than that one instance.
Def do the 180 stat and NEVER trust the factory gauge.
This is what I use:
This is what I use:
