Anything Else To Do to New (Used) Engine
Ok, a little background. I have an '03 with a fairly loud engine knock. No idea what caused it, but it's there. I'm not in the VIN range of oil pump failures, and I have installed an oil pressure gauge and have good pressure at all times. In the meantime, I found an '04 that was being parted out. I picked up the engine with about 80k miles on it. I'm getting ready to swap it over into my Disco. I've ordered new magnecors and have Bosch +4's ready to go. Is there anything else I should do to the new (used) engine before I drop it into the truck?
Bryan
Bryan
make sure it doesnt need ANY gaskets. since you have the engine out it will be A LOT easier to work on it so this will be the BEST time to change head gaskets and anything else that will be difficult to replace once installed.
others will chime in and give their 2 cents
Bryan
Bryan
No need to swap the engine. It is not like Every 2003 engine in the Vin range fails!! Just a small number.
Your 03 engine might not even fail, it probably won't. Just wait till it fails. No need wasting a good engine.
bcolins
Jul 13, 2013 08:43 AM
XxRoverAllOverxX
Oct 4, 2010 02:47 PM
oysterhead
Apr 10, 2010 08:06 AM
