Ashcroft cdl kit
Old Dec 10, 2024 | 10:58 AM
Mullins.cody's Avatar
Where does the plug that's on the Ashcroft housing plug into? Does the 03 not have a place to connect it?
Old Dec 11, 2024 | 09:53 AM
CharminULTRA's Avatar
Correct, 2003s (and some 2002s) don't have a CDL control nipple on the transfer case. You'll need either a replacement transfer case, or a new front housing that already contains the necessary parts. Something like this: https://lucky8llc.com/collections/di...cdl-update-kit
Old Dec 11, 2024 | 10:43 AM
That's the one I bought. Had an independent rover shop install it and theres a green and black plug I believe. I would have to go back under there a double check the color. That isn't connected to anything. Even the guy who installed it said he couldn't find a place to plug it in at. I read a on a few threads that that plug might be for the dash light.
Old Dec 11, 2024 | 11:04 AM
Have you considered emailing Lucky8 (if you bought from them) or Ashcroft? I'm hoping to do similar so I'd like to know the answer too.
Old Dec 11, 2024 | 12:39 PM
acg's Avatar
acg
This pic is a good comparison of the one without the CDL nipple (left) and with the nipple (right).
Old Dec 11, 2024 | 01:10 PM
My diff lock works fine just have a plug that's not plugged in
Old Dec 11, 2024 | 10:55 PM
Harvlr's Avatar
Doesn’t the Ashcroft “CDL” make the linkage unnecessary? Isn’t it a Automatic Torque Biasing diff that doesn’t need a selector?
Old Dec 12, 2024 | 08:22 AM
mollusc's Avatar
The photo above looks just like the front output section of a regular Land Rover transfer case. Ashcroft might make other things as well, but the part being discussed would seem to be the same as any other Rover CDL.
Old Dec 12, 2024 | 11:39 AM
Harvlr's Avatar
Ok. I was under the impression that the Ashcroft unit was almost synonymous with an ATB locker, but evidently not.
Old Dec 12, 2024 | 12:38 PM
H20nSnow's Avatar
ATB is the Ashcroft Torque Biasing differential. Ashcroft also makes the shifter and linkage to give access to the CDL functionality in the non 2003 (ish) t cases; and they make the parts to convert a 2003 case to have the CDL components.
TuckTuck
Oct 17, 2022 11:31 AM
LRD2Dave
Dec 3, 2020 01:55 PM
acg
Jan 10, 2014 08:25 AM
daigsdomain
Jun 10, 2013 12:40 PM
big cheif
Jul 1, 2011 07:01 AM
