Ashtray's official selfhelp/progress thread
Old Aug 25, 2012 | 05:17 PM
  #31
Rover De Land's Avatar
Originally Posted by ashtray
So Here is an update.
I got my ultragauge and it is such an awesome tool. Here are my current temps
Leave house straight to highway, stays at 194.00F
Slight stop and go with long roads in between lights, stays around 194-195.8
Real bad city driving with sitting for periods of 2-5 minutes until finally getting the light and departing, (while sitting) it spiked at 207.8 and right when I took off it went to 204.5, 201.2 and then stayed between ~196-199.## and only hit the 194.00-195.8 once I got back onto the highway. Once I got off and hit one short light, then another, and finally entered my apartment and parked, it hit 201.2 and stayed there as I turned it off because I did not want it to go any higher. What do you all think on this temps? Should I perform a good radiator flush? Or consider another t-stat? I'm in Texas and it only gets hot here. Really hot. During all of this the temperature outside was ~96-99 with traffic every where. I never floored it, just gave it proper throttle to get up to legal speed limit.
Your temperature is fine.. Please don't catch the paranoia bug that goes around here.. I had it once. Replaced too much stuff for nothing
Old Aug 25, 2012 | 06:34 PM
  #32
Discosomewhat's Avatar
I've programmed myself to worry at 220f. Your temps sound similar to mine and it doesn't overheat. I think the fan turns on at 212 on mine so 220 is what I am looking for to catch runaway temps early on.
Old Aug 25, 2012 | 09:14 PM
  #33
ashtray's Avatar
Originally Posted by lr2001silver
You should check into getting a motorad 180 t-stat if you want to run cooler. Also important that coolant system is properly bled. There are alot of components involved in a coolant system and any one of them can cause major problems.
Duly noted. Thank you. And considering the heat here and Texas' sun, I'd like to have it running cooler.
A question to all, what is the difference in a motor running cool(180's) to a motor running warm/hot(190-200's)??
Originally Posted by oilspotLR
Thats about my temp range on the montrad 180. On the highway I run 194.0 the entire time, A/C on or off doesn't matter. In city the max it goes to is 205. I set the alarm to let me know if it get to 212. However I'm running 50/50 pre mix. What are you using for coolant?
As I just inherited the truck, I'm not sure what is in it. But apparently it is doing a decent job. When I replace the bleed screw, I might just do a hardcore flush and then fill it up with PEAK 50/50. What coolant is recommended? I've heard PEAK 50/50 is good.
I'll try not too but it is a Land Rover and I just wanna make sure she's running tip top and at a comfortable temperature. haha. But I will set my ultragauge to beep at 212F or maybe 210.
Good to have a temperature to look out for. I doubt I will ever hit 220F. That seems like an overheat.
Old Aug 25, 2012 | 10:40 PM
  #34
Rover_Hokie's Avatar
British 4x4 is in San Antonio, Google them.
Old Aug 25, 2012 | 11:34 PM
  #35
I would be completely comfortable up to 215... Do not panic 200-205-215 is normal and will happen.. If you see 230 then cry and tear the truck apart/drive it off a cliff.. I don't even panic if it momentarily reaches 220.
Old Aug 27, 2012 | 12:10 PM
  #36
ashtray's Avatar
I actually already did and just got back yesterday from an awesome LR gathering and off roading event in Marble Falls. Awesome guys.
This made me laugh haha, thank though its comforting.
Old Aug 27, 2012 | 12:47 PM
  #37
ashtray's Avatar
quick AC question
The other day on my way to Marble Falls and back from, a white vapor substance started blowing out of my AC vents. The car was not running anywhere near hot, and it did not smell odd or anything like that. It was just odd to see. The AC was on 62F both sides. I turned it off and on and it just continued then eventually stopped. Any idea what it could be? It was not a smoke of any kind, it seemed like compressed air or vapor.
Old Aug 27, 2012 | 01:06 PM
  #38
jafir's Avatar
quick AC question
Condensation. Was it on auto? Or did you override it and have the re-circ turned off?
Old Aug 27, 2012 | 01:29 PM
  #39
lr2001silver's Avatar
Banned
Could be a pin hole in your heater core misting out of your vents. That's what it sounds like. Turn your heat on and let us know what happens.
Old Aug 27, 2012 | 01:36 PM
  #40
ashtray's Avatar
It was not on auto and I think it WAS on re-circ.
I'll try that on my next drive. Then let you know what happens.
