ATF change. WTF?
Old Apr 16, 2009 | 03:02 PM
DeadHead86's Avatar
8th Gear
Default ATF change. WTF?
Ok, so this is the first time Ive change the tranny fluid since I had the new(used) one put in. I drained it and only about a gallon (4 quarts) came out. This surprised me! Now what surprised me even more then that, was when I went to put the new ATF in. I was working on putting in the second jug (4 quarts) when about 1/4 the way down it started over flowing! WFT? The Disco I takes about 10 quarts does it not? Someone let me know where I dropped the ball please!
Thanks,
-Josh
97' Disco I SE
Old Apr 16, 2009 | 04:16 PM
AK Rover's Avatar
Obviously you didn't get all the ATF out. The torque converter holds fluid that you won't get out by just draining it.
Old Apr 16, 2009 | 05:43 PM
phidelt583's Avatar
What AK rover said is correct. If you just do a drain and refill you will only change about half of the fluid. If you are not doing a flush the best way to go is to put 3-4 quarts in and start checking the dipstick to see when you are at full level.
phidelt583's Avatar
This is a common mistake so don't fell bad
Old Apr 16, 2009 | 06:28 PM
It may not have been full when you started.
You have to go slow when adding trans fluid.
Old Apr 17, 2009 | 08:58 AM
discoxd's Avatar
i need to drain/refill mine soon too... i changed it a couple weeks ago and will probably do it again today/tomorrow to try and get a little more of the old fluid out...
Old Apr 17, 2009 | 10:06 AM
DeadHead86's Avatar
8th Gear
Damn... Duh! Wow, now I feel like an effing idiot. Ive been having so many issues lately, that I just got ahead of myself in thinking something else was wrong with er. Haha, thanks guys.
Old Apr 17, 2009 | 10:07 AM
DeadHead86's Avatar
8th Gear
That mess though... Let me tell ya. Took me like an hour to burn it all off the cats!
Old Apr 17, 2009 | 10:59 AM
Hey Josh,
Just so you know, one more "WTF" statement/question from you and I will delete you from this site.
If you are not mature to ask a question without swearing, then Dweb may be just the place for you.
collin Barrows
Aug 28, 2011 07:13 AM
Disco Alan
Apr 17, 2009 11:58 AM
sforb
Apr 15, 2009 11:52 PM
Jst4fun
Mar 19, 2008 10:08 PM
scottagnew101
Aug 7, 2007 08:44 AM
