ATF Change Question
Old Apr 16, 2009 | 12:56 PM
Disco Alan's Avatar
Default ATF Change Question
I'm planning on changing the ATF on my 03. The manual says 10.2 qt but not all of it will drain out, right? How much ATF should I have on hand? And is it OK to use synthetic ATF knowing quite a bit of old dino oil is in the transmission?
Old Apr 16, 2009 | 06:01 PM
AK Rover's Avatar
Yes, you will not get all the ATF out of the transmission. The torque converter holds an amount of ATF that you won't get out without preforming a flush of the transmission. I would change your ATF, drive a little then come back and drain and refill. Keep doing that until you feel like you have all the old fluid out.
Old Apr 16, 2009 | 06:21 PM
Buy more than you will need and then return what you dont use.
Old Apr 17, 2009 | 10:38 AM
Disco Alan's Avatar
Thanks a lot for your replies AK and Spike.
With the change-drive-drain-refill method I am a little reluctant to go with full synthetic as it's going to get expensive fast. I'm also considering Valvoline Max Life. It's probably a little early for my mileage (56k) but I guess it won't hurt anything. Thoughts?
Old Apr 17, 2009 | 10:56 AM
Do you know the proper refilling procedure for tranny.
Have a total of 6 bottles of ATF, or 5 and a bottle of Lucas treatment and you will be fine.
Old Apr 17, 2009 | 11:58 AM
Disco Alan's Avatar
Thanks Mike I've done a lot of research on this site and I "think" I know the proper procedure. I'm not going to have someone else shifting through gears while I'm under the truck though =P.
collin Barrows
Aug 28, 2011 07:13 AM
DeadHead86
Apr 17, 2009 10:59 AM
sforb
Apr 15, 2009 11:52 PM
Jst4fun
Mar 19, 2008 10:08 PM
scottagnew101
Aug 7, 2007 08:44 AM
