ATF & lucas oil Conditioner in power steering...
Old Nov 27, 2012 | 09:41 PM
mx468's Avatar
Default ATF & lucas oil Conditioner in power steering...
I was wondering if I could mix atf and lucas power steering conditioner together and use it in my truck? I have atf in it now as my power steering fluid. Thanks.
Old Nov 28, 2012 | 12:32 AM
Just use the Lucas transmission product. Lucas Transmission Fix : Lucas Oil
Old Nov 28, 2012 | 08:14 AM
mx468's Avatar
Hey Savannah, I meant use the atf in my power steering box as power steering fluid with lucas ps conditioner.
Old Nov 28, 2012 | 08:54 AM
Good point, my bad. See Texaco cold climate PAS fluid vs. Pentosin. Resolved? - DiscoWeb Message Boards for more numbers for various alternates to the speced fluid. Basically non-synthetic ATF is desired. Rover of course specifies unobtanium level fluids. And the Lucas folks make a power steering fix fluid, it is red and thick just like the tranny fluid, but must be a different formula.
Old Nov 28, 2012 | 09:00 PM
Unless you are having problems dont use any additives in anything, additives actually counteract the fluid properties.
Bottom line, as long as you use quality fluids you do not need additives because the fluids already have additives in them.
Paul Grant
Aug 10, 2014 12:29 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
bantham1
Oct 2, 2010 10:05 PM
jdelp
Aug 6, 2007 01:59 PM
