Autozone couldn't scan my truck
I had the same problem when I first bought my truck, it turned out my diagnostic plug was not getting power from the ECM, I looked at the plug schematics and just ran a new power wire to the plug and all was well, I later determined why I did not have power but I cant remember what it was (not a fuse)I think maybe it had something to do with the alarm for some reason, but not sure
your issue could be completely different though, I would agree first and easiest place to start would be to rule out a faulty scan tool. then maybe check the plugs power and ground.
Well, another store and still no luck. Had the car running to no avail. I think I can safely assume the trouble is in the port side of my truck and not the scanners fault.
Any advice on how to remove that kickboard to gain access?
Also, what might I look for once I am in there as far as potential problems. I will of course look for bent pins, but any other ideas of what to look for? Is there a wiring diagram I can find to trace wires?
Thanks,
Thanks,
demonlarry
08-29-2009 10:28 PM
