Autozone Viscous Fan Clutch
Old Jul 10, 2016 | 08:16 PM
CollieRover's Avatar
Default Autozone Viscous Fan Clutch
Has anyone been able to get the fan clutch for the 2002 DII viscous fan clutch onto the 2003 fan? I think the Hayden requires you to drill the holes a little larger, and that is fine with me.
Old Jul 10, 2016 | 10:50 PM
dr. mordo's Avatar
FWIW, I had no problems with the AZ clutch on my 2001 fan. I'd bet they're the same fan.
Old Jul 10, 2016 | 11:18 PM
Thanks Mordo.
Old Jul 10, 2016 | 11:52 PM
Shiftonthefly1's Avatar
At some point they switched to a one piece fan/clutch. I thought it was 03. My 04 had a one piece. Before I replaced it with an 02 fan.
Old Jul 11, 2016 | 12:10 AM
number9's Avatar
Was 03.
If original your 03/04 fans can't be installed on clutch as they are a one piece fan/clutch assemble. Many folks purchase a prior year new/used fan to install on the aftermarket clutch due to high cost of assy.
Old Jul 11, 2016 | 06:54 AM
The fan has bolts on the back of it, so I am guessing it is not the one piece. I will just have to try it.
Old Jul 11, 2016 | 09:37 AM
Best4x4's Avatar
If your 03 has bolts holding the fan clutch on it's a 99-02 fan blade. 99-02 fan blade has a ring around it. The 03/04 blade doesn't have the ring around it and the blade ends are exposed/open.
Auto Zone doesn't require any modifications.
Old Jul 11, 2016 | 10:30 AM
Thanks, I must have an '02. Maybe the one thing the last owner did right!
Old Jul 16, 2016 | 01:51 PM
The issues I had were not due to the fan, so I am going to return it. The fan does do a good job of cooling, but you will feel it on the engine. Although, I was going from electric fans so it was more pronounced. If I were in a hot climate or were going to cross a desert I may go this route.
jafir
Feb 10, 2017 11:08 AM
BajaXJ92
Oct 28, 2013 10:50 PM
DiscoRover007
Nov 19, 2012 11:20 AM
okdiscoguy
Sep 19, 2007 12:15 PM
