Aux USB port wiring
Old Oct 1, 2019 | 11:36 AM
Swazzy's Avatar
Default Aux USB port wiring
Hello, On my 2004 Discovery 2, I installed a dual Aux USB power port in one of the coin trays. My question is - where is the easiest place to tap the power for the port. Is it the cig lighter? Or is there something more easily accessed by removing the glove box? I'd like to use switched power - meaning only when the ignition is on.
Thank you in advance.
Old Oct 1, 2019 | 01:57 PM
Richard Gallant's Avatar
I believe the Cig lighter is switched
Old Oct 1, 2019 | 02:30 PM
whowa004's Avatar
Cig lighter is switched and it is where I tapped into for my aux USB install.
Old Oct 1, 2019 | 04:57 PM
Brandon318's Avatar
Just did this project, although, I ran everything into the center storage bin. Super easy to remove the center console to access the cig lighter.
Old Oct 3, 2019 | 01:23 PM
Discorama's Avatar
I tapped it at the fuse box, since you have easy access to it. It's a green-white wire coming from C0587 (pls see electrical manual) going to the cigar lighter
will rocket
Jun 29, 2013 09:02 PM
joefresso
Mar 21, 2011 01:30 PM
VanderLand
Nov 16, 2007 05:44 PM
03springer
Sep 27, 2007 12:43 PM
