Auxiliary Lighting
Old Sep 22, 2012 | 10:09 AM
N.United's Avatar
Default Auxiliary Lighting
Hi guys.
I am interested in installing four Hella 500 Black Magic's on my roof rack.
I have a 2004 Disco 2 S
I was looking at running the lights through the sun roof fuse seeing that my truck does not have sun roofs.
The problem is that the fuse does not appear to be wired to the battery. (tested with volt meter) So my question is...Is this easy to wire or should I find an alternative?
Thanks in advance!
Old Sep 22, 2012 | 03:30 PM
You may want to consider removing the A pillar trim and running a new wire (larger) and use a switch that runs a relay that socks the sherbert to the lights via an in-line fuse. IMHO the worst color for a Disco is "aftermarket toast". And you'll be looking at a snazzy hood blackout decal.
Old Sep 23, 2012 | 07:49 PM
N.United's Avatar
I am planning on running the wiring down the A-pillar i just figured powering the lights from a spot in the fuse box would be a simple solution.
barrysheene
Sep 18, 2009 04:57 PM
lipadj46
Jun 20, 2009 04:51 PM
AK Rover
Jan 11, 2009 11:40 AM
Street Wolf
Nov 23, 2008 02:42 PM
ghinesley
Nov 19, 2007 02:50 PM
