Axle Problems
Old Feb 11, 2008 | 07:41 AM
georgetrieste's Avatar
Default Axle Problems
From all of the horror stories that you read on here about axle and transmission problems, is there anyway to prevent these from happening? Preventive maintenance?
Thanks,
Old Feb 11, 2008 | 09:19 AM
Default RE: Axle Problems
There are no axle problems on Rovers. There is a front drive shaft issue with D2's needing to replace 2 front u-joints that did not come with grease fittings, and all that is required is to have them replaced with new joints with grease fittings.
Old Feb 11, 2008 | 11:18 AM
Thanks for the response Mike,
I have replaced u-joints in a 1979 Blazer, should I expect the same technique with replacing the ones in the Discovery or should I have an expect do this for me? Besides the dealer, Do you have a suggestion on where I can buy these in Denver?
Thanks,
cationmoted
Oct 19, 2012 07:39 AM
JBeezy53
Feb 22, 2010 11:14 PM
sanmigmike
Aug 24, 2006 03:37 PM
DiRanged Rover
May 26, 2006 12:39 PM
DiRanged Rover
May 24, 2006 07:36 PM
