Back Windows
Old May 12, 2008 | 08:59 PM
mlfore's Avatar
Default Back Windows
Both of my back windows quit working at the sime time in my 96 disco. No bad fuses anyone have any ideas as to what this could be. I dont have to have them working but if it breaks I try to get everything fixed and in good working order. My back sunroof also wanted to jump off of track a little when I closed it last how do you grease it up or can I do that? Thanks for all of you guys help you all really know your stuff.
Matthew
Chapin, SC
Old May 12, 2008 | 09:08 PM
DYNAMITE DISCO's Avatar
Default RE: Back Windows
Do they screw up at the switches at the center console or at the rear door switches...or both?
Old May 13, 2008 | 04:44 PM
mlfore's Avatar
They mess up at both they will not work at all its not the switches or the fuse I once read that there is a box inside the glove compartment and that the wire comes lose and you have to soder it back but im just not sure and I dont know where I saw that and how to get to it.
Old May 13, 2008 | 06:05 PM
Your windows stopped because your BECU has a cracked circuit board, hind of common on the older D1's.
As for the sun roof, you need to open it carefully, use the manual opener, once open, if nothing is bent, clean and lube all the slides and tracks. This should be done at least once a year if you want to keep them working.
Old May 13, 2008 | 06:16 PM
mlfore's Avatar
This BECU do I have to buy and new one or can it be repaired and if so where is it located? Thanks Mike for your help
Matthew
Old May 13, 2008 | 08:02 PM
I believe that it has been addressed on here before with pics, try doing a search and see what comes up.
I am not sure where the window ECU is but it does crack at a solder point, it is a easy fix once you find the ECU.
All you need to do is find the crack and then resolder it. No need to buy a new one.
Old May 13, 2008 | 08:14 PM
mlfore's Avatar
Thank you Spike I will do a search and see what I can find I knew I saw it somewhere and it must have been here thanks again
Old May 13, 2008 | 08:53 PM
HA, found it.
www.discoweb.org, go to the "tech" section, on the left is a list of tech tips, find the "rear window" tech tip, it even has pictures.
Nessa767
Aug 12, 2019 01:52 PM
colemtd
Nov 18, 2014 10:17 PM
kayaku
Nov 20, 2008 08:33 PM
JohnJaquaIII
Aug 15, 2005 04:19 PM
