98Disco rear windows will not go back up
Old Aug 13, 2005 | 04:51 PM
JohnJaquaIII's Avatar
Default 98Disco rear windows will not go back up
Anybody know how to fix 98 Disco rear windows? Worked intermittently and they finally stayed in the down position. All fuses and switches OK.
Old Aug 14, 2005 | 12:50 AM
Bait's Avatar
Default RE: 98Disco rear windows will not go back up
John,
This is a classic issue with the window lift ECU. A solder joint breaks inside and can cause intermittently operation. You can fix it if you can solder.
Old Aug 15, 2005 | 04:19 PM
Lebowski87's Avatar
.....or it could also be a sort of nylon wheel than runs inside a track to life the window up and down. Mine broke and fell out of the track causing the window to drop down and not work.
Nessa767
Aug 12, 2019 01:52 PM
rebelman
Sep 7, 2010 08:08 AM
Spencerfitch
May 28, 2010 06:34 PM
silverfish
Sep 12, 2007 08:30 AM
silverfish
Jun 26, 2007 11:24 AM
