Bad Axle Seal or Hub Bearing?
Old Aug 15, 2014 | 05:13 PM
TheWhiteRover's Avatar
Default Bad Axle Seal or Hub Bearing?
Yippee! Leaking from somewhere new... Big surprise there.
Look's like I'll be pulling something apart soon.
Attached Thumbnails Bad Axle Seal or Hub Bearing?-img_20140815_145628.jpg   Bad Axle Seal or Hub Bearing?-img_20140815_145636.jpg
Old Aug 15, 2014 | 05:37 PM
OffroadFrance's Avatar
Looks like the CV joint or the gaiter of the lower steering swivel joint leaking. I've got the same mess on my D2. I'm waiting to see what develops.
Old Aug 15, 2014 | 09:30 PM
Might be a stupid question...
But am I correct assuming it's leaking gear oil out of the axles? Should I consider topping off my diff?
I have some extra 85w140 from when I did the diffs and t-case last.
Old Aug 15, 2014 | 11:18 PM
Colorado David's Avatar
I would check the diff on a regular basis until you repair your leak, it's easy enough to do, but you probably won't lose much based on the photo. I tiny leak can look like a lot of fluid by the time it spreads out. If you start having drips, that's a different story.
Old Aug 16, 2014 | 04:52 AM
Good call, it could be the same as this https://landroverforums.com/forum/di...-sizing-68664/
Old Aug 16, 2014 | 08:20 AM
dusty1's Avatar
That is gear oil. Coming from the axle seal. Doubt you'll ever notice a fluid level drop, unless you go for months and months. You will allow more junk to get in there. Not that bad of a job. You don't even have to separate hub from shaft, just yank as a unit. And yes buy a good seal, not cheapo. I make it a practice to buy those in pairs. I have on occasion f'ed up a brand new one on install
Rover Newbie
Jun 22, 2014 11:07 AM
PuddleHopper
Feb 9, 2012 11:13 PM
Disrover
Aug 21, 2009 09:47 PM
jycsalas
Oct 29, 2008 03:01 PM
98xc800
Sep 30, 2008 04:51 PM
