Bad head gasket replacement?
Old Nov 22, 2015 | 02:46 AM
Georgebulldog's Avatar
Default Bad head gasket replacement?
So, I've put the engine all back together and looks great, started it and after listening to some head gasket blown videos on YouTube, sounds like one side is blowing.
I followed all instructions from RAVE to put it back together and it still does this....I'm certain I torqued the head bolts correctly but it sounds like a loud phut phut phut and has lost all power. I could barely get it back up my steep driveway.
Am I going to have to take it apart again? I would get codes but the OBD doesn't connect to the ECu - that's another thing I need to fix
Help. Please.
Old Nov 22, 2015 | 07:30 AM
coors's Avatar
Are you positive it is not an exhaust leak at the manifolds? Do you have secondary air injection make sure the flexible pipes are not cracked or leaking at the head
Old Nov 22, 2015 | 11:23 AM
chubbs878's Avatar
Or you are losing all of your compression on that one side because the head is not completely sealed to the block and gasket. I'm sure that you have another thread where you noted that these original heads have been machined "true" or you replaced them with a different set of rebuilt heads. If this is the case, then the gasket was put on backwards or the head didn't get torqued all of the way down. I mean, what else could it be? You wouldn't completely lose all engine power from an exhaust leak.
Old Nov 23, 2015 | 03:07 AM
well how embarrassing is this.....well quite.
Had my mate come over and see if he could put some fresh eyes on it, and he went immediately to the coil and HT leads, and we (he) diagnosed that the HT lead to cylinder 3 and 5 were the wrong way round. Switched then, and it runs like it should. Smooth. Quiet (for a land rover V8) and the power has come back.
I have a smirk on my face. Partly because its fixed, but partly because i'm a bit of a idiot to get them the wrong way round.
Oil pressure light is still on though.
I've checked the pump (ok), seals replaced, and changed the oil pressure sensor/switch. Still on. Any ideas?
Old Nov 23, 2015 | 05:56 AM
drowssap's Avatar
you will have to install a gauge so you can get the real oil pressure
Old Nov 24, 2015 | 01:07 AM
Yup, gauge on it to see what's what is the next step.
bennyb43
Nov 28, 2015 04:01 PM
outdoor7or24
Feb 26, 2012 08:02 PM
Draayer
Apr 25, 2011 06:39 PM
LRDon
Apr 16, 2008 12:51 AM
dc10freighter
Jun 15, 2007 09:47 AM
