Bad water pump = blown engine??
Old Oct 27, 2009 | 01:39 PM
imnothans's Avatar
4th Gear
Default Bad water pump = blown engine??
Can a defective water pump cause the engine to fail on a 2000 DII?
Old Oct 27, 2009 | 02:07 PM
antichrist's Avatar
If it leads to overheating.
I suppose a catastrophic failure could severely damage the block, but I've seen some nasty water pump failures and never seen that happen.
The temp gauge, assuming it was functioning, would warn you ahead of time though.
Old Oct 27, 2009 | 02:29 PM
imnothans's Avatar
4th Gear
Default DII water pump failure
That makes sense. The water pump failing by itself could not blow the motor but if the engine overheated it could.
Old Oct 27, 2009 | 02:34 PM
Sure it can, especially if you are not paying attention to your truck and how it is driving.
Why do you ask and how do you know it is blown?
Old Oct 27, 2009 | 04:08 PM
imnothans's Avatar
4th Gear
I actually have a customer who has a claim against them. The owner of the vehicle had a water pump installed and now they are claiming the water pump was defective and it caused the engine to "blow up".
I understand it could cause overheating but doesn't it make sense that if they continued to drive the vehicle while it was overheated and they ignored or didn't notice the warning lights or gauge that some fault lies with the driver?
Old Oct 27, 2009 | 07:53 PM
Yes, if they continued to drive it with it overheating then it is the drivers fault.
Does not matter what kind of car it is.
They are called idiot lights for a reason.
Old Nov 30, 2009 | 07:53 PM
mikeross's Avatar
4wd High
When it overheats too much... the bad water pump could definitely cause the blow up.. My friend has experienced this and it was really scary..
DiscoTanB
Aug 13, 2015 08:10 AM
masterseung
Jun 7, 2014 09:24 AM
dswilly
Oct 15, 2012 12:28 AM
zracin
Nov 3, 2011 12:17 PM
RangyEvan.CountyLWB
Mar 19, 2009 04:21 PM
