Bake Pedal leaks down and pumps up
Old May 7, 2013 | 11:21 AM
  #21
drowssap's Avatar
did you flush your system or just bleed the brakes?
Old May 7, 2013 | 02:45 PM
  #22
pprussell's Avatar
Default Problem Resolved on OP Vehicle
This turned out to be a number of things, and as each was identified or resolved, things improved. Here goes:
The rubber lines were replaced with the braided stainless (all six). After this, the pedal firmed up somewhat but still not what it should have been;
The bleeding was not done correctly by the dealer, the second time round, they used the computer and two guys. This made a big improvement, but still had issues of lots of brake pressure and not much stopping power. Still scary going down my hill in the morning;
Then, it seemed odd, there was no brake dust at all on the wheels. This seemed odd. Then it hit me. These were ceramic pads. That is why they did not work well down my hill in the morning, they were cold. Took them out to the hills and made repeated stops from fifty MPH on steep downhills, straight as an arrow, no fade. Took out someone else's Disco ll and we did the same thing and after second stop with factory linings it got a bit squirrely.
Learned that after five or six minutes of driving, the ceramic pads heat up from drag on the rotors. Then all is fine. So we are happy with the brakes now. I think the combination of the rubber lines, the incorrect initial bleeding and me testing them ice cold and not realizing they were ceramic, all contributed. Now we actually like the brakes. Even the ABS engages on panic stops. This it would not do cold before.
Spencerfitch
Sep 27, 2020 12:17 PM
FlyingZebra34
Apr 22, 2013 12:07 AM
discoboy
Dec 20, 2012 02:24 AM
morbid_icon
Apr 17, 2010 05:30 PM
slave600
Feb 28, 2009 02:33 AM
