band clamp size for intake to plenum
My clamp is kinda old and doesn't really snug up like it should. What size is the intake air tube onto the Bosch intake manifold? Is there a special type of band clamp (I'm sure there is)
Will something like this do?
I could be wrong about this but... .
https://www.roversnorth.com/parts/cn...lamp_70mm_90mm
I think that is it - it's #14 on the diagram here https://www.roversnorth.com/category..._ii_air_intake
which I think is the same size as goes on the throttle body -- but make sure -- give it a check. Don't rely on my awful advice hahaha
(and in the part description it says 70mm-90mm)
Thanks for that info and idea to look at RN. The DII seems to indicate a 70-90mm where the P38 (my car) seems to indicate a 80-100mm. My understanding is that the upper intake manifold was the same in both vehicles with Bosch intakes. Maybe not. Or just maybe either will work.
Poway
Range Rover L322 (3rd Gen)
Aug 24, 2023 06:59 PM
