Battery Drain Mystery
Old Oct 3, 2015 | 07:53 AM
Extinct's Avatar
Default Battery Drain Mystery
OK, I posting this hoping someone else has already crossed this bridge and figured out the problem.
03 Disco HSE - 134k on the clock - has the sat nav radio but otherwise no interesting electronics.
My battery has been going down overnight, just started happening. Newish battery - 1 yr old. Had it tested at Advance Auto just in case - tested good.
No lights on in the interior, no recent upgrades and modifications.
I pulled all the fuses/links from the engine fusebox one at a time and checked the current flow (I have a DVM with a current meter), maximum drain from any circuit was .3 amp, only one other circuit had any drain and it was more like .03 amp.
If anyone else has had this problem and figured it out please let me know.
Starting tonight I am going to start pulling 1 fuse at a time and letting it sit overnight, see which one makes a difference with the starting.
Thanks
Tim
Old Oct 3, 2015 | 02:11 PM
OffroadFrance's Avatar
The drain of 0.3 amps is one hell of a lot. My guess is that the security system, clock, ECU memory retention etc should only drain circa 20-40 milliamps in total. Your truck is draining 3 amps every 10 hours which is severe but shouldn't cause it to be a non starter. Which circuit/fuse drained 0.3 amps?
Try disconnecting the battery overnight when fully charged, test the battery and then test againg the following day to see whether it's losing it's charge overnight.
What make/model/type of battery are you using?
Old Oct 3, 2015 | 03:56 PM
R0VERGUY's Avatar
I had a mysterious battery drain at one point also. Switched from airbags to a 2" coil spring lift and I didn't turn off the SLS in the computer. After I took the truck to someone with a scanner to turn off the SLS system the battery drain stopped. If you no longer have airbags then I would make sure the SLS is turned off in the computer.
There is a large black box under the drivers side of the truck with all the SLS components in it. If don't have airbags and you can here clicking and noise coming from that box while your truck is off then the system is still active.
Old Nov 5, 2015 | 09:26 PM
Extinct's Avatar
I think that is probably it, I have noise that comes from that exact spot! Does anyone know if there is a way to turn it off without taking it to someone with the computer?
Old Nov 5, 2015 | 09:48 PM
Extinct's Avatar
Found it - great post by Savannah Buzz: https://landroverforums.com/forum/di...18/#post377199
dev99disco
Oct 12, 2014 04:57 PM
Rustybug
Jan 31, 2009 02:53 PM
shawnjones
Apr 24, 2008 03:15 PM
kingkitesurf
Jul 28, 2007 11:54 PM
Dopey
Jul 22, 2007 07:09 PM
