Battery drain problems
I think the BCU pulls some power thru there, which would be normal. But how much power would be the question. You'ld need a meter with amp scale. You'ld expect any drain for clock, CPU, BCU, radio memory - to be pretty low, way less than an amp. Don't know about your test light, but a regular tail light bulb will glow bright on a heavy drain, and not so much on low current drain.
Rustybug
01-31-2009 02:53 PM
kingkitesurf
07-28-2007 11:54 PM
Dopey
07-22-2007 07:09 PM
