Battery draining on 2000 Land Rover Discovery II
Old Jan 28, 2014 | 09:20 AM
dparham's Avatar
I think i have this post running in 2 spots still lol
Old Jan 28, 2014 | 09:31 AM
Jared9220's Avatar
Do you have SLS? If you have SLS and have switched to springs and did not get the computer switched to springs, then it will drain your battery while off. I had the same problem. If you have SLS you can crawl under the driver side and listen to box that has all of the SLS stuff in it while the truck is off. If you here it clicking then it is still active and draining your battery.
An electric drain can be a bear to track down. I hope it is as easy as switching a setting in the computer. Good Luck
Old Jan 28, 2014 | 09:33 AM
etsZac's Avatar
The buzzing tic-toc sound from the ABS seems to be normal, I can also hear it with the hood raised. I have had it parked for a couple weeks at a time and haven't noticed any battery issues. If there is a draw from it it's very, very small so I doubt it's what's causing your mysterious battery dump. How old is your battery? Some batteries can start acting up and will spontaneously discharge, and I've had some that I can trickle charge back to being usable (but not reliable) again and some that never hold a significant charge after the first random discharge.
Old Jan 28, 2014 | 09:34 AM
dparham's Avatar
Hmmm good question... I bought it preowned.... Hmmmm
Old Jan 28, 2014 | 09:38 AM
dusty1's Avatar
the draw from that modulator is teeny tiny. it would have to sit for a loooong time to drain significantly. like months
Old Jan 28, 2014 | 09:40 AM
dparham's Avatar
I dont have that problem i just knew i replaced battery year and a half ago but I've left it for weeks and still was ok... I just never noticed that sound before and aound usually =electricity lol
boom_r6
May 27, 2010 08:03 AM
asikuy
Jan 5, 2010 09:13 PM
richief556
Jul 23, 2009 08:29 AM
94LWBrangie
Sep 27, 2008 11:23 AM
barcroft
Sep 27, 2008 09:44 AM
