Battery Draining
Battery Draining
Hello,
My battery keeps on draining, it is a new battery with a new Alternator....BUT when i have the car all tunred off and when it is very quiet i seem to always hear a clicking sound on the left side of the hood. The clikcing sounds comes every 45 seconds to a minute and i suspect that this is what is draining the battery.
I have my Three Amigos lights tunred on, i also have my SLS light turned on since i switched my suspension to a Coil from the self leveling system.
Is it possibble that the clicking sound is coming from the three amigos or the SLS light when the car is fully turned off which is then causing my battery to drain.
Also, i had installed a Remote start a few months ago...i hear they say that remote starts can mess with the electrical system.
I hope i can pick your brains with this.
Thanks,
Gerard
2000 Disco
Chicago
Thanks,
Gerard
2000 Disco
Chicago
Most likely remote start. Clicking could be the ABS, normal to a point. SLS parts left behind can try to level truck when key is off. See attached wiring diagram, note that three valves and pump share same ground point, valves get battery power from SLABS. See that coomon ground point is C0811, separate pix attached for that. Take it off and tape up and valves can't draw power. Other wire (C0810) is fuel pump, you'll know if you took off the wrong one. You can also attach an amp meter or just a test light in series with the (+) battery lead, high current drains will make test light glow. Pull fuses untill it goes away.
Most likely remote start. Clicking could be the ABS, normal to a point. SLS parts left behind can try to level truck when key is off. See attached wiring diagram, note that three valves and pump share same ground point, valves get battery power from SLABS. See that common ground point is C0811, separate pix attached for that. Take it off and tape up and valves can't draw power. Other wire (C0810) is fuel pump, you'll know if you took off the wrong one. You can also attach an amp meter or just a test light in series with the (+) battery lead, high current drains will make test light glow. Pull fuses untill it goes away.
I registered just to thank you fine gentlefolk.
My ladies 99 Land Rover Discovery II has been having the exact same issue. The "wonderful" mechanics told her the clicking was nothing and wasn't the source of her draining battery and would persist for the life of this vehicle. After reading this and seeing the diagrams, I removed the same ground and 2 hours later still no clicks and her battery is still running strong.
This has been an annoyance for months and was causing her to hate her Discovery! Thank you so very much!!!
94LWBrangie
09-27-2008 11:23 AM
