Battery light came on, P0734 and low voltage
Old Feb 10, 2015 | 07:32 PM
Tomzsix's Avatar
Default I had the same experience
My battery light came on along with the two little green lights, flashing. This was after a long trip from Portland to Seattle and back. So I cleaned my battery posts and cables. Problem solved. So far. And this occurred two weeks ago. But I will be diligent about watching the alternator.
Old Feb 11, 2015 | 03:42 PM
Fast951's Avatar
If you do end up getting a replacement battery pay close attention to the CCA (Cold Cranking Amp) rating. Yours at 690 seems a bit low for the weather you're dealing with. I have seen Group 34 batteries with 800CCA rating which would probably serve you well in the cold temps you are dealing with. Check your oil viscosity, too. Definitely want to run a 5W-30 or 5W-40 in those crazy low temps to make starting in the morning easier. Maybe even consider one of those Mobil-1 full synthetic oils with 0W-30 or 0W-40 rating?
Old Feb 11, 2015 | 08:40 PM
vonrock's Avatar
I did get a new battery. Got the wrong one!
But just finished putting in the new used alternator and everything looks good!
Old Feb 12, 2015 | 08:16 AM
drowssap's Avatar
Get at LESS a 800 cca battery
rimskych
Member Group And Special Buys
Sep 28, 2014 07:23 AM
TRIARII
Jan 22, 2013 07:39 PM
rekogniz1
Oct 19, 2009 11:46 PM
kfx4001442
Aug 27, 2008 08:29 PM
