Battery Post Shims, where have you been my whole life
Old Jul 4, 2022 | 09:38 AM
keninnc's Avatar
Default Battery Post Shims, where have you been my whole life
I can't believe I never knew about this product: Battery Post Shims.
Anyone who has a mid late 1990's to mid 2000's Land Rover knows the challenge of getting a tight fit on the battery posts.
Best $4.00 I've spent on the D2
Old Jul 4, 2022 | 10:39 AM
nashvegas's Avatar
Yes, but there's a big BUT with these and I stopped using them. They have to be on quite tight. And the battery hold down has to be on tightly as it should be. Otherwise, these sleeves can pull up off the battery posts over time and cause the same issues as a loose battery cable.
Old Jul 4, 2022 | 12:16 PM
mln01's Avatar
Ken, I have shimmed the battery clamps with a toothpick. Anything to take up space. Worked well.
A few years ago I graduated to deforming the clamps just a bit with a pair of Vise Grips. That has worked well for me.
p.s. And yes, they are Vise Grips. Not vice grips, as they are so commonly misspelled here and elsewhere. Vice grips would be a whole 'nuther thing ...
Old Jul 4, 2022 | 11:57 PM
greisinb's Avatar
I got sick of dealing with shims and installed a set of mil-spec battery connectors- I would highly recommend this mod, like a top 5 mod I would make to a Disco.
Old Jul 5, 2022 | 08:40 AM
jastutte's Avatar
do you have a link to the product you used?
Old Jul 5, 2022 | 09:11 AM
greisinb's Avatar
No problem:
Amazon Amazon
You have to cut the stock battery cable as long as possible because there isn’t a lot of extra cable to work with. I have a group 65 battery which is a little wider which negates a lot of that problem. Carefully strip the wires with a utility knife before crimping the terminals on. I have a cheap hydraulic crimper ($40) which is a really worthwhile purchase if you will be doing any sort of electrical work.
The fit is great and I haven’t had any battery related electrical issues since installation.
DakotaTravler
Oct 25, 2021 08:17 PM
redwhitekat
Jul 25, 2021 07:39 PM
greisinb
Nov 28, 2020 08:56 PM
Disco Eagle
Mar 10, 2019 05:30 AM
Daedrix
Feb 10, 2013 12:04 PM
