Belt squeeling
Old Nov 19, 2007 | 07:18 PM
Tastang's Avatar
Default Belt squeeling
I cleaned my motor for the first time last weekend and now the belt is squeeling. I have tried spraying the belt with WD-40 many times and it stops squeeling for a bit but then it comes back and is very annoying. Does anyone have any ideas? Thanks!
Old Nov 19, 2007 | 07:30 PM
Willie 00D2's Avatar
Default RE: Belt squeeling
You should not spray anything on the belt. I have had squelling belts before. The only way to fix it is to buy a new belt. I have tried belt dressing before and it did nothing to silence the belt.
Willie
Old Nov 19, 2007 | 07:38 PM
Tastang's Avatar
That's what I was thinking...just wondered why it started after I sprayed off the motor. I'm changing the head gaskets this weekend and will throw a new belt on then. I'm thinking of replacing the water pump while I'm in there also but the cheapest one I have found is 109.00 at British Atlantic.
Old Nov 19, 2007 | 08:02 PM
okdiscoguy's Avatar
Might want to consider a new fanclutch/ fan assembly from there as well. If the clutch locks, it will send your fan through the hood and radiator. At 100K, you should seriously consider...
Old Nov 19, 2007 | 08:12 PM
Tastang's Avatar
Thanks for the info...Where is the best place to find one? Anywhere cheaper than $250.00? I just finished the 90K mile service and now with the head gaskets its starting to add up pretty quick. Other than the fan clutch the only other thing I need to do isreplace the U-joints...no signs of going bad but from what I've heard on hereyou don't want to wait until its too late.
Old Nov 19, 2007 | 08:23 PM
okdiscoguy's Avatar
Atlantic British is where I got mine from. It comes with the fan though....
Do the driveshaft ASAP.
Old Nov 20, 2007 | 09:41 AM
Before you start throwing parts at your truck, deal with the more common problems. First, since you have glazed up your belt, spraying it with WD 40, I wouls suggest replacing the belt, also depending on your mileage, I would look at replacing both the belt tensioner and idler pulleys, both of which are major loose belt squeal issues. leave the fan clutch alone until after you replace your belt.
01disco2
Oct 1, 2009 09:48 PM
GREENGRASS
May 7, 2007 11:01 PM
handsome rob
Apr 2, 2007 08:49 PM
98roverguy
Sep 22, 2006 06:47 PM
riebs
Aug 29, 2006 03:05 PM
