Bench testing electric
Old Sep 28, 2014 | 08:57 AM
GGhost's Avatar
Default Bench testing electric
2004 rear wiper motor 3 pin connector on motor, which color is positive 12v wire
Old Sep 28, 2014 | 11:15 AM
GGhost's Avatar
So the park connector (brown/yellow) on the motor with power turns on and rotates back and forth a small bit. The 3 pin center I assume is ground (green) but touching either side just Sparks and nothing else. Left side is green and red which from rave seems to be power but spark and heat a bad sign!
Am I testing it correctly? If park works shouldn't motor? There is 14v at connector in rear door on left and center, multimeter on center and Y/B on right shows nothing.
Any help here would be appreciated
Old Sep 28, 2014 | 11:38 AM
OffroadFrance's Avatar
Someone might come along and help you with testing specifics. Be careful what you do as the whole rear wiper system is extremely complicated for what it is and interdependent on the windshield wipers.
The interlocks to my recollection are:
  • Rear wiper operates alone
  • Intermittent rear wiper (sychronised with windshield wiper)
  • Reverse gear initiated rear wiper.
  • Stroke sychronisation with the windshield wipers (otherwise you'd get driven mad)
If you checkout the wipers electrical circuitry in the RAVE manual you may understand the sequence which (I may stand corrected) is linked also to the BCU (Body Control Unit) which is yet another ECU. It drove me mad so better luck
Old Sep 28, 2014 | 11:54 AM
GGhost's Avatar
Overly complicated... Next step would be direct wire with an on off switch!!!
Kidding
Soccer Dad
Sep 16, 2014 09:43 AM
A5scott
Jul 29, 2012 11:19 AM
landyjd
Defender
May 21, 2011 11:34 AM
possibly owner
Sep 8, 2009 10:30 PM
sheelhorse
Jun 25, 2009 10:39 PM
