Best cigarette port phone charger for 2004 D2?
Old Aug 21, 2021 | 05:39 PM
greisinb's Avatar
Originally Posted by Harear
Is there a good beginner’s thread for removing the console and rewiring? I’m sure it’s easy but like I said I’m a total newbie.
If you do a quick forum or Google search for “Discovery 2 center console removal” a few guides will show up. It’s not hard to do, I’ve had mine apart 2 or 3 times. Like I said, you don’t need to remove the whole thing, you just need to get it loose. In particular you don’t need to to disconnect the parking break, which I find to be the most difficult part. A few notes though: 1) If memory serves, no “rewiring” is needed, just unplug the old outlet and the wires should plug in to the new one as they are all standard spade connectors. Mind the polarity by making sure the black wire is plugged in to the negative terminal. 2) The shifter head just pulls right off- DO NOT twist it or you will break the mechanism. It takes some effort but will suddenly “let go.” If you aren’t careful you will smack your face when it does (learn from my pain!).
Edit: I was able to find the guide I used, it’s a guide for installing a center diff lock but the first step to doing that is to remove the center console:
http://www.discovery2.co.uk/diff_lock.html
Old Aug 21, 2021 | 10:48 PM
04disco2va's Avatar
Great info all. Thanks.
Old Aug 22, 2021 | 07:10 AM
mln01's Avatar
One other thing I didn’t see mentioned is that the lighter socket in the D2 is a slightly different dimension. I’ve heard it referred to as a “cigar” lighter, versus a cigarette lighter. It may be that it is slightly deeper, which means the adapter you tried simply doesn’t reach all the way to the bottom of the socket. I replaced the one in my truck years ago with something I bought at NAPA, and I’ve never had a problem with any charger adapter since then, whereas I did before. That does still require removing the console and wiring in something new.
Mickey7621
Aug 10, 2021 10:00 PM
Mickey7621
Aug 10, 2021 08:11 PM
NewToTheTwo
Oct 12, 2019 07:57 PM
jbarr89
Jun 21, 2016 12:43 PM
