1999 disco 2 wont start
Old May 28, 2018 | 05:38 PM
Jon Forry's Avatar
3rd Gear
Default 1999 disco 2 wont start
I have a 99 disco 2 and i drove to the store with no issues then the next morning it wouldn't start. Checked the fuses and relays first but nothing was wrong. Then checked the fuel pump and no sound from pump. I replaced the fuel pump but it still wont start, any other ideas on where to go next.
Old May 28, 2018 | 06:29 PM
BackInA88's Avatar
Is the engine cranking over when you turn the key? Just not firing?
If so it is most likely you crank position sensor.
I just changed mine today for the second time since I bought the truck in 2006.
Old May 28, 2018 | 10:33 PM
Jon Forry's Avatar
3rd Gear
Yes it does crank but just wont start. I will tey replacing the crankshaft position sensor
Old Jun 3, 2018 | 02:40 PM
Jon Forry's Avatar
3rd Gear
Still wont start, i noticed on the forum another issue similar to mine. My window regulator broke a few days prior to this issue. Cranks but sounds like it is not getting fuel. Possible ECM not syncing correctly
Old Aug 21, 2021 | 12:50 PM
BKeene's Avatar
Did you ever figure out what the issue is? Mine is doing the same so I swapped the cps, fuel pump, and fuel relay. Still nothing.
Old Aug 22, 2021 | 08:04 AM
Jjcopen's Avatar
I too am having the same problem. Anyone figure it out? I do not have any spark at the plugs. Replaced cps and still nothing. I also have a new fuel pump.
ToddD
Feb 11, 2015 09:44 AM
discoHUSS
Jul 24, 2013 04:27 PM
jrkstore43
Sep 28, 2012 04:16 PM
awillis
Apr 10, 2012 01:53 PM
moxiep3
Oct 2, 2010 10:11 AM
