Better Valve Cover Gaskets
Old Sep 28, 2018 | 08:08 AM
Fast951's Avatar
Default Better Valve Cover Gaskets
My valve cover gaskets from Atlantic British are leaking (significantly) after only 2 years and about 20K miles. Frustrating! Can anyone recommend a better quality gasket set that will not leak? This is a stupid problem to have such a short time after an engine replacement.
Old Sep 28, 2018 | 09:56 AM
nathanb's Avatar
You almost certainly just need to tighten the fasteners. But if the gaskets are actually broken, a can of Permatex The Right Stuff gasket maker will make a better valve cover gasket than any pre-cut gasket.
Old Sep 28, 2018 | 02:22 PM
Fast951's Avatar
I tightened all four bolts on each side to the proper torque upon first noticing the oil leaks. Didn't help.
Old Sep 28, 2018 | 02:33 PM
Best4x4's Avatar
Make sure your baffle on the passenger side valve cover is clear & no clogged or you’ll be pressuring the engine & the valve cover gaskets will always seep. FV308 is a nice upgrade vs the plastic baffle.
Old Sep 28, 2018 | 09:45 PM
CollieRover's Avatar
You can get 1/4” Torque wrenches, I have one for working on bikes. It’s possible it got overtorqued/unevenly torqued.
edit: sorry, just noticed u torqued them. Disregard the above.
Fel Pro makes a molded gasket that is way way better thannproline. Mahle also has a molded gasket, but I have not used it.
Celto 4
May 15, 2015 03:49 PM
BFox15
Sep 7, 2011 08:22 PM
maing74
Aug 26, 2011 10:23 PM
thospb
Dec 1, 2010 06:06 PM
lifewithoutanet
Jul 24, 2008 08:00 PM
