The big trailer wire question
i have a walmart trailer wire that has the green white brown and yellow just a standard 4-flat that i want to splice into the land rover one (i have a 2002 discovery 2 se7) i dont want to buy the one from british atlantic cause i dont have that kind of money to spend on a trailer wire. im using this guide http://www.discoweb.org/trailerwire.htm to do the wiring but i dont have a red wire can i just tie the brown into the brake light on the land rover also or would that cause a problem.
Here is the one I installed on my 2003 DII:
229-56146 - JEGS High Performance
I also added this to keep everything nice and clean:
229-58300 - JEGS High Performance
Been using it most every weekend since installation without any problems. It's got external power and converts the blinker and brake lights into a 4 wire system.
Thanks
The trailer connection is no longer attached to my truck. It was missing when I got it. Just cut wires hanging underneath. I put a converter on the end of the wires to cover to a 4 wire system and it lasted about 3 months and the end corroded so bad it was unusable. I replaced the end only to find that the converter had failed. I only had left turn signal and nothing else. That is when I decided to keep the wiring inside the truck.
gruehle
07-27-2020 09:10 AM
mtr1974
02-28-2013 09:37 PM
JAMESTHOMAS
07-14-2012 11:58 PM
