The big trailer wire question
Old Jun 23, 2013 | 04:21 PM
ninjaff21's Avatar
Default The big trailer wire question
i have a walmart trailer wire that has the green white brown and yellow just a standard 4-flat that i want to splice into the land rover one (i have a 2002 discovery 2 se7) i dont want to buy the one from british atlantic cause i dont have that kind of money to spend on a trailer wire. im using this guide http://www.discoweb.org/trailerwire.htm to do the wiring but i dont have a red wire can i just tie the brown into the brake light on the land rover also or would that cause a problem.
Old Jun 23, 2013 | 05:36 PM
ralphobell's Avatar
The brown wire is for your running lights. So when your headlights are on your lights on the trailer will be on. See attached image.
Old Jun 23, 2013 | 07:51 PM
PalmettoDisco's Avatar
You need a converter because the turn signals and brake lights are separate See link for an example.
Trailer Light Converter 5 Wire To 4 Wire
Old Jun 24, 2013 | 11:46 AM
SuperSport's Avatar
Here is the one I installed on my 2003 DII:
229-56146 - JEGS High Performance
I also added this to keep everything nice and clean:
229-58300 - JEGS High Performance
Been using it most every weekend since installation without any problems. It's got external power and converts the blinker and brake lights into a 4 wire system.
Old Jun 24, 2013 | 02:41 PM
mark d's Avatar
I bought one of the convertors from Amazon for $10, compared to the $30 at Autozone. I ended up not using it when I found that there was a factory installed convertor behind the passenger tail light. You might look and see if you have one.
Old Feb 12, 2014 | 08:08 PM
badassbmwm3's Avatar
Can you post a pic of the converter so we can see what it is we should be looking for exactly?
Thanks
Old Feb 12, 2014 | 09:14 PM
ralphobell's Avatar
It will look similar to this:
Land Rover Trailer Wiring Kit (Same Fit As Genuine Part # HIL-734)
Old Feb 12, 2014 | 11:54 PM
jimvw57's Avatar
I wired in my own converter behind the pass tail light (from Amazon) and I keep the wiring/connector inside the truck. Minnesota winters are tough on electrical connectors exposed to the elements.
Old Feb 13, 2014 | 07:35 AM
wkburns's Avatar
Do you currently have the European style trailer connector?
Old Feb 13, 2014 | 08:28 AM
jimvw57's Avatar
The trailer connection is no longer attached to my truck. It was missing when I got it. Just cut wires hanging underneath. I put a converter on the end of the wires to cover to a 4 wire system and it lasted about 3 months and the end corroded so bad it was unusable. I replaced the end only to find that the converter had failed. I only had left turn signal and nothing else. That is when I decided to keep the wiring inside the truck.
gruehle
Jul 27, 2020 09:10 AM
rmgoutfitters
May 7, 2015 11:07 AM
mark d
Apr 11, 2013 01:03 PM
mtr1974
Feb 28, 2013 09:37 PM
JAMESTHOMAS
Jul 14, 2012 11:58 PM
