Big troubles with the Tranny
Old Mar 15, 2011 | 10:12 PM
tgwaldop's Avatar
8th Gear
Default Big troubles with the Tranny
All,
A few days ago we started to hear a grumbling from beneathe the old Disco 2. I figured it was a drive shaft and told my wife I would get to it Monday night after work. That was a Sunday. Did I mention that my 88 XJ-S had a bad alternator and my 98 GMC Sierra had a leaking intake manifold gasket? SO monday at work I get several frantic phone calls from my wife - something made a horrible noise under the LR and it stopped, needed a flatbed to get home. I get home, LOTS of tranny fluid underneath it. I am now confused. The front drive shaft came apart in front of the transfer case, and when it did, it bashed a big chunk out of the side of the transmission. So it would appear that I need to get a new transmission. There is an outside chance I could JB Weld that piece back in but I am not holding my breath.
Sooo the big question is what transmission is compatible with my LR? There are a few trannys on ebay, but 99 Disco 2 is not listed as a compatibility for any ones that I have found.
Thanks all
Old Mar 15, 2011 | 11:46 PM
mwindth's Avatar
Originally Posted by tgwaldop
...I am now confused. The front drive shaft came apart in front of the transfer case, and when it did, it bashed a big chunk out of the side of the transmission. So it would appear that I need to get a new transmission....
Another testament to replace front drive shaft with greaseable parts ASP and grease every 5K miles...
I would not hold mine either on this one...new transmission in the future
Thanks all
Any D2 transmission will fit in another D2...
Old Mar 16, 2011 | 05:19 AM
Bundu's Avatar
Banned
You shoulda looked at it on Sunday, or sooner...
Old Mar 16, 2011 | 06:13 AM
jeffh's Avatar
Yep new tranny for you as well as a new front prop shaft. As noted earlier any DII tranny will work. and make sure you get a rebuilt prop shaft that has GREASE Fittings. I had the same thing happen Still have the IMPACT zone to show for it... look at it this way for a couple of thousand bucks you have just extended the life of your LR
Old Mar 16, 2011 | 06:22 AM
Bundu's Avatar
Banned
Here's a tranny for cheap. I know the listing says transfer case, but it's actually the tranny plus the transfer case. They don't know **** from shinola...
http://cgi.ebay.com/ebaymotors/00-01...item19bd88e910
Attached Thumbnails Big troubles with the Tranny-land-rover-transfer-case-002.jpg   Big troubles with the Tranny-land-rover-transfer-case-003.jpg
Old Mar 16, 2011 | 07:14 AM
David A's Avatar
Man that sucks! I wonder how many people lost there tranny this way?
Old Mar 16, 2011 | 07:26 AM
texmbr's Avatar
Many....you would be amazed.
Shane83
May 5, 2011 07:48 PM
Wanderer
Mar 4, 2010 08:09 AM
sm3earl
Feb 15, 2007 12:26 PM
Bene
Oct 26, 2005 11:17 PM
Dave_Liverpool
Jun 22, 2005 11:29 AM
