Bigger 18's?
Old Nov 9, 2008 | 08:37 PM
nervous4ever's Avatar
Default Bigger 18's?
Does anyone know the biggest size above the 255/55/18 that will fit w/o rubbing. I have an '03 se.
Old Nov 9, 2008 | 11:07 PM
snowdude's Avatar
Default RE: Bigger 18's?
nothing will fit above that unless you want to ruin your truck.
Old Nov 9, 2008 | 11:13 PM
Jupiter Rover's Avatar
ORIGINAL: snowdude
really now..
285/60 r18. roughly 31.5"
Are you planning on offroading? It is cool if your not. But 285/60 is more for street use. You will rub while flexing off-road.
these tires are Pirellis.
Old Nov 10, 2008 | 03:06 AM
jos's Avatar
jos
i have 265-45-20, they fit perfect.
Old Nov 10, 2008 | 07:35 AM
ORIGINAL: nervous4ever
Are you planning on lots of wheeling, 18's have a tendency to get their sidewalls ripped out when play off road.
Old Nov 10, 2008 | 10:57 AM
Goose_Cat's Avatar
I have been running 265/65 18s and they fit just fine. Technical courses no problem.
Old Nov 10, 2008 | 01:06 PM
NW_rockhound's Avatar
If you change the tire size, don't forget to replace the spare with the same size! You might need to get an adapter to fit the oversized spare on the truck too.
Old Nov 10, 2008 | 01:47 PM
Thanks Guys. I do some offroading. Mudding not rock climbing.
Will the 285/60 r18 be ok or should I go smaller?
Old Nov 10, 2008 | 02:25 PM
smaller with no lift for offroading.
Old Nov 10, 2008 | 04:48 PM
Goose, What kind of tiresare you using.
You don't rub at all with 265/65 18s?
Elhoff
Nov 22, 2007 09:39 AM
Blizwinter
Freelander
Aug 30, 2007 09:42 PM
Mr. Krisztian
Aug 16, 2007 11:36 PM
EL GALLO
Feb 22, 2007 06:09 PM
Randy Lover
ROAMING WITH FRIENDS
24
Jan 31, 2007 06:38 PM
