Bleed fuel line? After I had it apart?
Old Jun 21, 2012 | 05:57 PM
jafir's Avatar
Originally Posted by innzane
P0705 (i think) the xyz switch
P1668 security signal high
I got the xyz out now, opened and tested, cleaned one contact.
Gonna plug it back in and try it click by click to see if it's my issue now.
that "P1668" code is what makes me think BCU or IDM. Do you have access to Rave? If so, open the workshop manual for D2 and press ctrl-F and search for that code. It will describe your situation almost exactly.
My 99 did this, and it ended up being the ECM or BCU got wet. I replaced them with a pair from a salvage yard for about $75 each, and all is well. I'm not sure if that is the route to take for you though, just because of the weird issue you've got with the indicator on the dash.
Old Jun 21, 2012 | 10:07 PM
innzane's Avatar
Thanks for the rave tip, not the easiest thing to navigate at times.
And yeah, it all sounds like the bcu except the odd dash lights.
But them dash signals for the gear do come from the same plug so possible.
JavaDiscoII
May 29, 2010 04:33 PM
xb70valkarye
Mar 15, 2009 06:46 PM
Jupiter Rover
Feb 27, 2009 01:04 PM
George Dow
May 1, 2008 11:44 AM
