Bleed screw
Old May 23, 2007 | 12:13 PM
flyingasics's Avatar
Default Bleed screw
I would think that this would be an easy thing to find, but I don't see it on my top rad. hose? Could someone have installed new hoses w/o the bleed screw? Also, where exactly is the plug that is actually on top of the rad??
Old May 23, 2007 | 01:08 PM
98roverguy's Avatar
Default RE: Bleed screw
What year etc.? There should be a bleed screw on the left hand top corner of your rad.
Old May 23, 2007 | 03:10 PM
2000 DII, I've taken off the fan shroud and looked , but there are just more screws to hold on the bottom of the shroud. I guess I missed it....
Old May 23, 2007 | 03:25 PM
BogdenZ's Avatar
On your year, there's a bleeder built into the hose assembly. If it's the original hose kit that came on the vehicle, it'll actually be in the middle of the hose that crosses over the shroud.....built right into the hose itself.
The newer replacement hose kits have the bleeder built into the T-connector that joins the radiator hose, to the water pump hose, to the t-stat hose.
Old May 23, 2007 | 03:36 PM
Did you find it yet?
Mike
Old May 24, 2007 | 07:42 AM
Nope, no screws on the hose that I can see, looks like it was never there. I have ordered a replacement kit for the rad. hose, they looked kinda old anyways.
akbarkhan
Aug 18, 2013 01:29 PM
MARGE
Feb 29, 2012 05:24 PM
Jason_B
Apr 18, 2010 05:11 PM
99discoverysc
Jan 14, 2010 04:37 PM
JAC
Oct 1, 2009 04:02 PM
