bleeding the brakes
Old Nov 27, 2008 | 09:49 AM
caleb's Avatar
Default RE: bleeding the brakes
Does anyone know how this Nero program works ? i am downloading the Rave CD and could use some helpCaleb
Old Nov 27, 2008 | 11:51 AM
Jeff In Katy's Avatar
I would sure check all the simple fix's for the trilogy lights before you go spending all that money on stuff you might not need.
Your trilogy lights can go off just by having mud covering up your ABS sensor, in the wheel well . Spray it down real good and disconnect your bat for a while, and see if the trilogy lights come back on when you reconnect it.
Almost every time I go thru the real muddy wet stuff, my trilogy lights come on and I spray it down real good and reset them by un-hooking my bat for a little while.
Old Nov 27, 2008 | 12:28 PM
Unhooking the positive battery cable won't clear a true set of ABS faults, only the proper scanner can do that.
Old Nov 27, 2008 | 01:12 PM
It will clear out the "trilogy" or "three amigos" lights depending on what made them go off in the first place. It's been done on and off the trail many times, by me and other club members.
Old Nov 27, 2008 | 11:48 PM
pilsner's Avatar
ok so if i want to try the spray off the sensor method before i order a modulator where and how do i spray?
i know it is on the front passenger side wheel but where? and do i need to remove tire and rim first?
instructions please
thanks
Old Nov 28, 2008 | 08:11 AM
ORIGINAL: Jeff In Katy
Once the trio is set, there is no way to clear them except with a scanner. I would say your trio has been coming and going and not set yet.
kdscott100
Aug 22, 2012 11:44 PM
FightOnUSC79
Nov 26, 2010 09:43 AM
rbruton
Other
Oct 6, 2010 09:12 AM
dillhole
Jun 26, 2008 09:13 AM
skewett
Jul 8, 2007 11:28 AM
