Bleeding brakes
Old Sep 24, 2014 | 04:29 PM
grizzdog50's Avatar
Default Bleeding brakes
I just removed the abs shuttle valve and had to remove the lines from the modular does anybody know the procedure for bleeding the brakes
Old Sep 25, 2014 | 07:27 AM
Andy2Rover's Avatar
It ain't easy brother....search the forum, there is plenty of info
I'll wait for OffRoadFrance to chime in
Old Sep 25, 2014 | 07:43 AM
drowssap's Avatar
If you look on the site from down under (aust.) i think someone had a way to run the ABS pump manually.
Old Sep 25, 2014 | 11:21 AM
OffroadFrance's Avatar
X1 ................ nothing like the search facility on here eh, or RAVE when you've 'killed' the primary brake circuit ............... hmmmm......... research is good beforehand ............... usually too late afterwards ............
Old Sep 26, 2014 | 10:40 PM
lordmorpheus's Avatar
Perhaps I may have completely gotten lucky when I did my ABS mod and replacing the shuttle valve seals. I just gravity bled at all four wheels over the course of about 4 hours, then took a drive around the neighborhood in low range, 1st gear with HDC on and just let the HDC get the rest of it out.
Old Jan 22, 2015 | 08:47 AM
Fuddy's Avatar
Bleeding Brakes - Solo - Australian Land Rover Owners
Old Jan 23, 2015 | 04:47 AM
Running the modulator pump in isolation doesn't evacuate the air on both the A & B brake circuits and can burn out the pump if you don't know what you are doing. Both of the shuttle valves have to be activated to distribute the brake fluid to both brake circuits, to wit, A&B which cannot be achieved by merely activating the modulator pump. There are options, Nanocom, Hawkeye or LR Test Book plus other very expensive diag: equipment. There are other ways which are less reliable and hit and miss using the HDC etc but they are very hit and miss. It depends on how one values their stopping power and can tolerate spongy brakes or the worst condition, total brake failure.
FightOnUSC79
Nov 26, 2010 09:43 AM
rbruton
Other
Oct 6, 2010 09:12 AM
caleb
Nov 28, 2008 08:11 AM
dillhole
Jun 26, 2008 09:13 AM
skewett
Jul 8, 2007 11:28 AM
