Blinking "m" and "s" lights
Old Apr 9, 2008 | 08:34 PM
Millchil's Avatar
Default Blinking "m" and "s" lights
Speaking of warning lights... I have a 2003 Disco II that seems to be having some issues today. The "M" and "S" dashboard lights are blinking as well as the "D" in both the dash indicator and the gearshift itself. It wouldnt start after this happened at the gas station earlier tonight till I had it jumped. And only started then reluctantly. I hope there is something I havent thought of that doesnt require a zillion dollars at the dealership to troubleshoot this. Thoughts?
One thing I have heard is that if I simply disconnect and reconnect the battery, it will trip the computer and work fine. That sounds iffy to me, but what do ya'll think?
Thanks! And I apologize in advance for not really knowing what I am talking about when it comes to fixing my own car!
Old Apr 9, 2008 | 08:54 PM
KeizerRover's Avatar
Default RE: Blinking "m" and "s" lights
It might be a 12V supply issue. Check the condition of your battery. For further diagnosis you need to have autologic of T4 to see what fault is coming on the screen. Generally it's somewhere else down range. Find a reputable shop with the proper testing equipment.
DiscoOn22s's Avatar
check your battery teminals first. take them off and clean the battery posts and your terminal connections. autozone or advanceauto will do it for you for free. they scrape the corrosion off. if that dont work have them test your battery. worst comes to worst your alternator might be shot. check that other stuff first.
angasreid
Dec 16, 2023 07:45 AM
RegT
May 21, 2010 10:22 PM
likenmori
May 30, 2008 10:01 PM
jwb
Jul 13, 2007 01:58 PM
jbrandtpollock
Jun 26, 2007 08:20 AM
