Block Color Grades?
Don't be so sure, they all had blue marks on the front. The mark you are looking for is under the valley pan gasket on either cylinder #5 or #6. Ive only seen one block that I could make out the color of the dab, it was red, but the crank broke and trashed the block. Lady went to Walmart and had her oil changed. It was a 2001 P38 4.6.
Luckily she was dry enough to work for a while. Got the intake off, the exhaust Manifolds unbolted, and ALMOST got the driver's side head off.... Until my woes continued. The very last bolt in the main back of the head, the higher one down inside next to the valve, stripped the head. Jeez.
Angies disco
08-02-2018 05:02 PM
knightmetro
03-24-2014 07:01 PM
1999rover
02-17-2014 01:41 PM
