Block Pressure test
Old Apr 30, 2018 | 04:14 PM
328Driver's Avatar
Default Block Pressure test
Does anyone have a link to a step by step process of pressure testing these blocks while it's in the car? I.e. where to get the plates and bolts?
Old Apr 30, 2018 | 08:37 PM
abran's Avatar
If the heads are still on you can do a leak down test.
Old May 1, 2018 | 12:28 AM
328Driver's Avatar
Heads are off. Any other options?
Old May 1, 2018 | 12:47 AM
Jeff Blake's Avatar
No clue where to get a kit for that. Never heard of one. Probably have to make it yourself
I don't really see the point of pressure testing a cold block
Old May 1, 2018 | 06:46 AM
328Driver's Avatar
I would think a cracked block would leak on a pressure test cold or hot
Old May 1, 2018 | 08:50 AM
Kdo58's Avatar
What cylinder was it leaking out of?
Old May 1, 2018 | 08:59 AM
abran's Avatar
I’ve got the kit. The cracks in a block are normally very minuscule, and only start to leak when the block heats up.
That’s why the pressure test is so frustrating. Are any of your Center pistons steam cleaned(3,5,4,or 6)?
Old May 1, 2018 | 09:00 AM
abran's Avatar
Engine Block Leak Tester by Motorcars Ltd part BLOCK.TESTER - MotorcarsLtd.com
Old May 1, 2018 | 10:35 AM
OverRover's Avatar
You just have to love the "modified water pump".
Old May 1, 2018 | 12:57 PM
abran's Avatar
Yeah, but the water pump they sent me was so warped I had to send out to have decked at the machine shop as it would not seat flat against the front cover.
humroot
Jul 22, 2019 06:33 PM
Extinct
Feb 3, 2018 03:48 PM
Hephaestus
Jan 28, 2016 12:00 PM
knightmetro
Feb 27, 2014 10:35 AM
0304Disco
Mar 24, 2011 02:55 PM
